AttachGHS perspective view not showing anything
G’day McNeel,
Just a little bug. While reviewing the ghs objects with the attachghs window open, the perspective view does not show the objects unless something is rendered in the display.
See screenshots.
Only difference between these two shots is the hull layer is turned on/off.
Hmm- not getting that here so far- if possible can you post that file here or to tech@mcneel.com? Thanks.
I’m pretty sure I know what is causing this. I’ve logged this into our bugtracking system.
Thanks for reporting this.
