I am currently working on illustrating a book that involves 0ver 400 CAD plans presented in a custom Display mode based on Technical.
because the model is absolutely huge, over 5GB spread out over 4 .3dm files I require the use of work sessions and it does help however I have come across a weird behaviour.
I will run through the process, I have an empty template scene that has all my units, dimensions, etc defined in it , it also has 4 cubes with the 3 types of hatch needed for my drawing included in the scene and applied to the geo.
I am not using dynamic sections, I am just using clipping planes and hi res print to pdf due to the massive file sizes
If I open the first part of the model that I want to make an attachable work session I use the same template and assign all the hatch’s to the layers, I also purge unused to be be sure, There are no blocks.
this is is where the issue happens, as soon as I attach the file in the work session manager , if I go into the hatch options in the properties window it has created a new version of EVERY hatch with the prefix of the work session name, even if those hatch’s are not used, at this rate I will have thousands of new hatch’s clogging up my file.
The extra hatch’s cannot be manually cleaned up and deleted in the window as the delete is greyed out, I assume because its reading it from a work session but the extra hatch’s are not in the file to start with.
I had only just figured out why hatch’s were not coming across with the work session and now this.
Incidentally that’s why in include geo in each file with the hatch’s assigned, its to deal with this issue.
I have also tried this in Rhino 9 Beta but due to the solid hatching not rendering black but grey or white only in that mode despite all overrides being set correctly in Technical mode I cant use that.
I cant upload the actual files as I am signed to a major publisher but if it will help I will build a scenario for testing if it helps, but its as i have described.
below you can see what I mean, the attached part has a file name of Axial_Profile.3dm with only the one hatch applied in the scene which happens to be the blue highlighted on. so what are all the other ones?
PS its also creating new annotation and dimension styles as well.
