Asuni CAD Internal Error
This started happening to some files when I tried to open it normally. The error message appears and rhino closes.
The trial version of VisualArq expired, so I was thinking that has something to do with the error.
I’m able to open the file by inserting it into a new rhino file.
Anyone else experiencing the same problem?
I did experience that once. I just disabled the VisualARQ and Tibidabo module in Options menu.
This doesn’t explain the error message but may allow you to open your files.
Hi Icbaz,
Can you send me these files you are trying to open to visualarq@asuni.com? We will check them out and determine the reason of this error message.
Thanks,
Thanks for the suggestion!
