Here is my first prototype for a Party Table, that I call Astrodon.
In order to make the shape I first use six points in space, 3 for the feet and 3 for the columns. These points are connected using blend curves.
These curves are solidified
Then I cut the ends using Mesh Iso Splitting
Object is scaled along Z, then remeshed, then some minimisation. Then scaled back.
Mesh is minimized futher and various remesh size are tested.
Mesh is then clustered (150 pieces), inner points are removed and rivets position (1506) is calculated. Multiple seed for the clustering are used in order to have no self intersection of flattened pieces.
In order to see something all pieces are put
A tool to make the ends is then applied, this tool take the naked edge of the mesh, the different cluster and different rivets and place new points in order to connect them to this interface piece.
Then some tools are applied, they make the bayonet holes, then another tool place other hole on these pieces. As I work with 1 mm aluminum these pieces have 2 sheets that are riveted.
A tools is done to add connector to the pieces, these shaped are unioned,
Then every think is nested (I use sparrow here). The main pieces with name and nesting 2d are baked in a rhino file for use in production.
In order to help me for production as pieces are not marked, I made a pdf with all pieces
lets say that without dictionary the puzzle is very hard to solve.
Whole script
Then aluminium sheet are sliced
Then pieces are cutted with my laser
Then pieces are deburred (not very clean)
Then assembly time, here is one of my main error, I didn’t make holes or slits in the pieces so they are a bit too rigid so it is difficult to bend them. Perhaps I will use thinner (0.5 mm) stainless steel if I redo this technique of construction. I use Rhino to see the name of the piece, then the dictionary to find it, then the 3d view to bend it by hand.
So at the end I am quite happy with most of the idea except the state of surface due to the fact that pieces are too rigid.
