Associative Hatch Broken, bug?
I use “# hatch” to make associative hatches connected to curves. However, it gets broken all the time, is this a bug? Moving the curves either using sub object selection or point control, makes hatches break. It also messes up different hatches as well.
Hatch broken.3dm (612.7 KB)
Hello- I see this - I also see that the parents for each of the hatches are a lot of curves, not just the obvious ones per hatch… so presumably you made all of these at once, correct? At the moment I suspect this happens because some of the curves are open - I’ll test.
I used region/boundary instead of closed curves. And yes, the hatches are made at once the curves are all drawn. However, I didn’t choose to combine hatches.
