Assigning Attributes for Block Elements Elefront
I am trying to create an embed block with the geometry inside that is on different layers. I thought that is what the “attach attributes” component would do but it doesn’t seem to work, so I must be missing something.
elefront Block Attribute.gh (15.6 KB)
I found always dificult to work with this plugin, because of lack of information.
Basic information here : Blocks | eleFront
The most helpfull I found is there (highly recommand this course. you could have a free trial): Elefront 101: Comprehensive Course on Distributed Data Models with Rhino Objects | ThinkParametric
I’ll let someone else answer for your specific need :wink:
C.
Attributing the attributes to the geometry is not necessary in your definition. If it is required, then you will need to detach the attributes to insert them in the Attribute param of the defEmbed component.
Thanks that helps.
