Assign solid barriers which can truncate other objects (blocks)
I want to do scaffolding works for this building.
House.pdf (2.1 MB)
I use a modular scaffolding system. It consists of vertical post segments (standards) and horizontal beam segments (ledgers).
I assign a standard and a ledger to a block in order to count the quantity used in my project.
Then I array the standard and ledger to surround the building.
Most of the blocks will go inside the building and I don’t want to manually delete them.
Is it possible to assign the building as a solid object which can truncate the unwanted block elements automatically?
