assign global parameters to type , instance.gh (24.1 KB)
hey , i was exploring the parameters in rhino inside Revit and i created a type parameter with a value also i created a global parameters and i wonder if there is a way to connect the global parameters to that type parameter or any other future test if i want to connect tha global parameter to an instance parameters i have done some research to make it just with native RIR component but i failed so any help please and thank you .
Hi aymane laf,
Global parameters are only valid in the Project setting, modifying a Type Parameter is at the Family level.
I believe you can have a Formula in a Type Parameter that is associated with an Instance Parameter that can then be associated in a project.
