Hello, I’m doing some draft angle analysis and i want to put the color i have to the elements (so i can select them by color)
Here is an example
If you got any doubts please ask me.
Best Regards
André
Here is an example
Best Regards
André
Hi Andre - run ExtractAnlaysisMesh
, hide or delete the original and set the viewport to Rendered mode - you can also SetObjectDisplayMode
to Rendered.
I got this but the mesh colors remain the same of the original part,
What I want to is to assign the color the Draft Angle Analysis to each mesh respectively
Best Regards
A
Quite old but… exactly what I needed!
I discovered that this command is not functional in Rhinoceros Version 7 SR26 (7.26.23009.7001, 2023-01-09) and extracts a mesh without any colors.
Thanks
Hi Julio -
Thanks for reporting this. I’ve put it on the list as RH-73089 ExtractAnalysisMesh: No color information on the mesh
