Arrowheads and Print Preview - Two Wishes
Two little wishes:
  1. Can the display of arrow heads be tuned up so that they don’t look like bottlenose dolphins when line weight is bumped up?
  2. When in Print Preview display mode, can we have a command line option added to allow objects that are set to ‘No print’ in line weights to either a) not display, or if that’s seen as too risky, b) at least be knocked back to a very pale grey?
Hi Matt -
I see that, thanks. I guess the thick line goes right to the end, passing through the arrowhead. I bet this might be hard to fix…
http://mcneel.myjetbrains.com/youtrack/issue/RH-34284
Hi Pascal. I had a feeling you might say that :grin: . I think I can remember it being discussed some time ago but can’t find anything on a search. Perhaps it was in the old newsgroup.
