Hello guys.
i created a “X” shape form in Grasshopper with MetaBall Command, but later when i wanted to Ran Polar-array on it, i ran into a problem which is the curcular Sections in new Intersection points cant merge to each other, i try to fix the paths and indexes but i cant figured it out.
in the picture i marked the issue, i want to “Red Intersection area” becomes like “Yellow Intersection Area”
I Uploaded The “gh” File on the Topic too.
Thank you, sorry if my English is not Good Enough!
Meta-Ball.gh (14.4 KB)
Secondary Donwload link
Hi!
You can graft your planes list instead the lines list, so you have a tree structure that have a branch for each plane, and you can build up a simpler definition.
See attached Meta-Ball_re.gh (12.8 KB)
