Arraying group of objects around a curve from base point
i have an object which i am trying to array to a curve. I am having trouble controlling its rotation and exact point of array. I can do it manually with rhino but would like to automate it with grasshopper. Any ideas?
Object and curve to array:
Result i am trying to achieve:
Array Object.gh (33.9 KB)
I would do something like this using PFrames along the Curve, rotating those frames by a Range of angles, then Orient the petal on those planes
note, it will take a lot of time to compute because your petal is super heavy :slight_smile:
Array Object_Re.gh (41.2 KB)
missing
Array Object_2022Sep29a.gh (31.4 KB)
P.S. Minor refinements:
  • Added slider to PFrames ā€˜Nā€™ input.
  • Added Shift List to remove the first petal that was below the ground plane.
Array Object_2022Sep29b.gh (32.3 KB)
Ah great, thanks:)
Thank you!
