I am attempting to array the green bits along a curve on a surface. The command rotates the extrusion to some seemingly arbitrary angle then duplicates down the curve as expected. I need the bits to be rotated per the surface normal. I believe this worked that way in the past. Any thoughts.
Thanks for your input. I see that you got the result I am looking for. I was selecting the object on the end of the curve - not a correctly oriented object at 0. Thanks for the reminder.
Robb
