I have a curve and a circle on it’s end. With the ArrayCrv I did this:
I will cut rescale circles and cut half and a sweep2, but… my questions are… how can I copy these circles to specific positions on the curve, such as the control points?
And, when copying, how can I copy objects constrained to selected curve, or a selected curve direction?
in this case, you’ll probably want to draw the circle on the top cPlane… run the command, choose the circle as the object to orient… select the center as the base point…
then use the Copy and Perpendicular options after you select the curve.
Hi!!
I activate my license for 90 days,and I used it, but the time expired. I ´m using Rhinoceros to create some geometries for my degree final job. Exist any chance for extend my license more days???
