Array problems
click Icon, choose one Cure, input 1 in X,press “Done”, And input 1 in Y, press “Done”, there is nothing, like press ESC key, input _Array command, the same. But input other like 2 or 3, etc, but 1 in Y, it is work.
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2014-07-28 (519)
OS X version: 版本 10.9.4(版号 13E28)
Plug-ins
//usr/lib/libmecab.dylib
Hardware information
Computer hardware
Hardware model: MacBookPro11,1
Processor: Intel Core i5-4288U CPU @ 2.60GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel Iris (null)
Memory: (null)
Screen size: 1440 x 900
Displays: 彩色 LCD
Third party kernel extensions
com.parallels.kext.usbconnect (9.0 24237.1028877)
com.parallels.kext.hypervisor (9.0 24237.1028877)
com.parallels.kext.hidhook (9.0 24237.1028877)
com.parallels.kext.netbridge (9.0 24237.1028877)
com.parallels.kext.vnic (9.0 24237.1028877)
com.parallels.filesystems.prlufs (2010.12.28)
USB devices
Apple: Internal Memory Card Reader
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: Apple Internal Keyboard / Trackpad
Generic : USB Storage
Logitech: USB-PS/2 Optical Mouse
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-8.28.30
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 无
Mip map filtering: 无
Anisotropic filtering: 无
A 1x1 array is just the original object, there is no copying action required from Rhino.
How can I do 1x1x5? Rhino windows can work like this.
I just try 5X5 is not work on Rhino Mac?
Hello afay,
You did not say you wanted to create a 3-dimensional array. I tested the command with x=1, y=1 and z=5, and it works ok. Both with selecting a z-distance and specifying a starting point, and with specifying two points.
Max.
Sorry made your confuse, but on my Rhino Mac, after I input x=1, an y=1, then, there is nothing, _array command will exit.
Now I try re-instill Rhino Mac.
I re-installed Rhino Mac, it work well. Thanks a lot!
Hey Maxz,
Very sorry.
I re-install Rhino, it is work good start, but know I think it still some problem for “ARRAY”, it still can’t work 555, I have re-install it many times.
Please check the vido
Hello afay,
I followed your video exactly, and you are right, it fails! BUT:
when you do not wipe with your cursor over the preset value before typing a new number, but just type the new number it works OK.
@Marlin : maybe you should check this out to see if it is a bug.
Max.
There appears to be a problem when clicking the Done button between each step. I’ll look into this.
Instead use just the keyboard when entering array information; you don’t need to use the mouse at all. For example:
Number in the X direction: 5 Return
Number in the Y direction: 5 Return
Number in the Z direction: 5 Return
