Hello there,
I have an question how to array object between 2 different curve like this? There is a difference distance if only use array command. I spend a lot of time if i do it manually using gumbal rotation.
Thanks.
TEST CHAIR FILE.3dm (2.8 MB)
Hello there,
Thanks.
Hi @Kevin_Vol
Since the two curves (top and bottom) aren’t equidistant and don’t have the same curvature, you can’t repeat the same shape, and expect it to fit. You’ll have to create a separate curve for each “section”. You can do that by taking the top and bottom curve, dividing them into however many pieces you need, create the top and bottom semi-circle at each section and then connect the semicircles to get the full shape.
Thats what i need, Thanks Jakob!
Feature request:
Add “Array2Crv” and “ArrayMultiCrv” commands in Rhino 10.
