I’m in an ongoing battle with my local friendly squirrel. He has his own feeder, but keeps going after the bird food. I made a locking cap that works. However, he is slowly gnawing it down, so I’ve decided to make it a little beefier. While at it, I thought I’d add knurling to the knob. Then I realized easier said than done. How would one array around this taper with a constantly changing angle and arc?
ExtractSrf the surface to be knurled.
Rebuild the extracted surface to make it non-rational. Use enough points to be accurate enough.
SeamSrf to move the seam of the extracted surface to a flatter quad.
Rectangular surface with the height of the extracted surface and length of the circumferance of the extracted surface.
Create the shape for “knurling”.
Divide one edge of the rectangular surface with number of divisions twice the number of knurlings.
Move the knurling shape so it is centered on the first point in from the edge of the surface.
Array the knurling shape with the unit space equal twice the distance between points.
FlowAlongSrf Cap_test DC01.3dm (2.6 MB)
I thought about that but haven’t tried it. However it would not taper the knurling, and it would keep all the knurling at the same orientation to the curve.
The method above tapers the knurling to keep the ratio of knurling width to space between the knurls constant, and also orients the knurls along the isocurves, which are not perpendicular to the circumferential curves (except at the quads).
Typo, no corrected. It should have been “non-rational”, not “non-ratio”.
A rational NURBS curve or surface has one or more control points with weights other than 1. A non-rational NURBS curve or surface has all control points with weight 1.
FlowAlongSrf can behave strangely when used with rational surfaces. To avoid those problems I like to rebuild rational surfaces as non-rational surfaces. Usually the non-rational surface will deviate from the original rational surface, and more control points will be needed for the deviation to be acceptably small.
When you use Rebuild select the degrees and number of points which results in the desired accuracy. For curves Rebuild automatically displays the maximum deviation between the input and the result.
If the maximum deviation is too large try increasing the number of control points, or possibly increase the degree. I usually use degree 3 or 5. While Rebuild is active you can change the number of control points and the degree and see what happens.
The only time Rhino creates rational curves and surfaces is when a command for a special shapes such as an arc, circle, ellipse, sphere, ellipsoid, etc are used, or when a revolved section is created, or if the Weight command is used to change the weights of control points from 1.0.
