Is there a simple way to label and print a (selected) series of vertically stacked separate surfaces (for laser cut)?
Hello - I am not sure this addresses your question but I’ll try - Select the surfaces (or copies) and use NonmanifoldMerge
Select the result and UnrollSrf
> Explode = Yes
This will lay out the surfaces side by side - is that what you want?
Explode
to separate the merged faces.
Wow, this is cool, never thought of that…
Usually I do it like the following:
One small advantage of this method is that it also works on curves, not just surfaces. But I might try to make a script that works on either using @pascal 's method…
Brilliant, exactly what I wanted, thanks!
Cheers
Thanks for the Shear variant - new to me as well. Lacks the option of labeling, but has other uses I can think of.
Cheers
