Hi @Clemens,
many thanks for replying the post you share was helpful indeed. I maned to fix the first argument but the type of the second argument still has an error. seems that a nested list type of input is expected but I’m not sure how to make a nested IEnumerable[IEnumerable[Line3]].
the error is attached below
Runtime error (ArgumentTypeException): expected IEnumerable[IEnumerable[Line3]], got List[Line3]
Traceback:
line 42, in script
Below I have attached the test code
clr.AddReferenceToFileAndPath('C:\\Users\\ukeer\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\7.0\\Karamba3D\\2.2.0.12\\Karamba.gha')
clr.AddReferenceToFileAndPath('C:\\Users\\ukeer\\AppData\\Roaming\\McNeel\\Rhinoceros\\packages\\7.0\\Karamba3D\\2.2.0.12\\KarambaCommon.dll')
from Karamba.Geometry import Point3
from Karamba.Geometry import Line3
from Karamba.Elements import LineToBeam
from System.Collections.Generic import List
from Karamba.Materials import FemMaterial_Isotrop
from Karamba.CrossSections import CroSec_Trapezoid
import ghpythonlib.components as gh
import Rhino.Geometry as rg
#nodes
pt_1 = Point3(0,0,0)
pt_2 = Point3(50,0,0)
pt_3 = Point3(100,0,0)
node_list = [Point3(0,0,0), Point3(50,0,0), Point3(100,0,0)]
nodes = List[Point3](node_list)
#line
line_list = [Line3(Point3(0,0,0), Point3(50,0,0)), Line3(Point3(50,0,0), Point3(100,0,0))]
lines = List[Line3](line_list)
#material
clt_material = FemMaterial_Isotrop("beam", "beam_a", 1155, 69,57,78.5, 23.5, -23.5, FemMaterial.FlowHypothesis.mises, 1e-4, None)
clt_crosec = CroSec_Trapezoid("beam", "beam_a",None,None,clt_material,30, 100, 100)
#define beam element
a = LineToBeam.solve(nodes, lines, False, True, None, None, None, None, clt_crosec,True, None, None, None)
any thoughts?
Finally many thanks for the instructions on how to share docs.
-Keerthana
