AreaMassProperties for multiple curves
@dale @stevebaer
It would be nice if RhinoCommon supported the calculation of AreaMassProperties for multiple curves, similar to the way that the AreaMoments command works on multiple curves.
I have - for now - created a native implementation using ON_MassProperties with a few dirty hacks to get it into RhinoCommon. I think it would be better if is supported out-of-the-box.
A few things I noticed: the AreaMoments command does not detect/support counter-clockwise curves, and it would be nice - at least in code - to be able to have nested curves with opposite planar orientations to add/subtract area and mass. Furthermore, the command does not notice that the curves are not in the same plane, and I think that calculation of the moments only makes sense if the curves are all in the same plane.
If you want I can share my native-to-.NET implementation.
Hi @menno,
There is this:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_AreaMassProperties_Compute_9.htm
and this:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_AreaMassProperties_Compute_10.htm
Does this help?
I’m guessing most of our customers don’t pay attention to curve direction. So imposing this could potentially lead to some confusion. If you have a tool that works for you, I’d say continue to use it.
– Dale
@menno - I’ve updated my reply above…
Thanks @dale - I feel a bit stupid for having missed the methods you point out above :joy:
We’ve all been there lol…
