Rhino 5 shows the result of the command immediately.
Thanks, I see that. It’s not a deselection but a screen redraw - you’ll see the point if you tumble the view for instance, with the object still selected. Anyway, should be an easy fix - thanks.
http://mcneel.myjetbrains.com/youtrack/issue/RH-34920
