Hi there,
I was wondering if it’s possible to compute area moments relative to the cplane coordinate system, not the world axis. Is there a way?
Thanks
Ruy
Hi there,
Thanks
Ruy
Hi @ruy.sevalho,
Here is what is available in Rhino WIP:
https://developer.rhino3d.com/wip/api/RhinoCommon/html/T_Rhino_Geometry_AreaMassProperties.htm
Does this help?
– Dale
Hi Dale,
By the looks of it only do the calculations respective to the world axis are done. At least thats only what appears in the properties of the class. I don’t how much demand ther would be for the properties be calculated respectives to construction plane coordinates also. I’d use it.
Thanks
Did you see the CentroidCoordinates<xyz>
properties?
Does Rhino’s AreaMoments
do what you need?
– Dale
Hi Dale,
The CentroidCoordinates<xyz>
still uses axis parallel to the world axis, althoug with the origin shifted. I wanted to do the calculations baesd on an axis system not parallel to the world axis. I can always move the geometry and get the results I want, but it woul be nice to have the option to choose which coordinate system are used in the calculations
Thanks a lot
