whenever I switch to the arctic view the camera near clipping plane moves farther away compared to other views. is there a reason why this happens?
I am not sure, and example would be great.
You can try this.
- Show all 4 views at once.
- Then Zoom Extents in all 4 views.
Does the building stay centered in the view? Or does a view go blank?
If one does go blank, then there is one or more objects a far distance from the building. This is messing up the camera frustum.
- Find the object by selecting the building
- Using Invert to select the small objects far away
- Delete
