bianca
(Bianca)
March 5, 2020, 12:45pm
1
I have the following problem with arctic mode: I have a specific view that I want to export using Arctic mode, the camera has a 20mm Lens Length and it’s quite low so whenever I try to “ViewCaptureToFile” the image that I get has weird horizontal lines. I guess it’s because the lens length is quite wide, but is there a way to go around this and get a perfect image?
Below you can see the Actic mode export and same view using Shaded mode:
wim
(Wim Dekeyser)
March 6, 2020, 12:36pm
2
Hi Bianca - I’m not seeing that here with a simple scene:
Could you please run the Rhino
SystemInfo
command and copy-paste the result here? Also, please provide a 3dm file that shows this behavior on your system.
bianca
(Bianca)
March 6, 2020, 2:57pm
3
Thank you very much for your fast response!
Indeed, the file that has this issue is very big, the file has close to 200mb. This is the file info:
Rhino 6 SR23 2020-2-24 (Rhino 6, 6.23.20055.13111, Git hash:master @ 8106edaa648ba209a8fc587f0f7fcccbaac09169)
License type: Commercial, build 2020-02-24
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: EW-C0D9E-019
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro P4000 (NVidia) Memory: 8GB, Driver date: 12-6-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.66
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2019
Driver Version: 26.21.14.4166
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.23.20055.13111
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.23.20055.13111
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.23.20055.13111
C:\Users\ew501\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin” 0.0.20013.952
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.23.20055.13111
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
And I’ve attached the 3dm. In the Named views I have saved the views that have this problem.
Bianca
bianca
(Bianca)
March 6, 2020, 2:59pm
4
The 3dm is uploaded at this link:
https://we.tl/t-YIIQdAm1XU
Thank you,
Bianca
