Hi there,
I’ve been trying to figure out how to flip the anchor position or change the alignment of columns for quite some time now. (With column settings and the anquor position I manged to change the position from left to middle or right.)
Flipping or mirroring the curve doesn’t have any effect.
Hope you can help me with this issue
- also: Is it possible to define the distance between the columns instead of only changing the count?
- Is there an easy way to distribute the columns within the length of the curve?
Thanks a lot!
anchor position.gh (16.1 KB)
