I’m trying to create a solid spherical triangle shape on curved surface, The problem is that the triangles in the middle of the surface are forming correctly as solid shapes, but the triangles at the ends are not. They appear in incorrect shapes.How can I ensure that all triangles, including those at the ends, are solid and have the proper solid spherical triangle shapes
a remark I’d suggest to -almost- never connect multiple wires directly to the same input (while pressing SHIFT) because you have no visual clue of the order in which they were connected… I’d always prefer a Merge component for that:
if you also want to compact a bit your definition by taking advantage of data trees instead of repeating the very same serie of components on slightly different starting data, here is one -among the many- way to do that:
