It seems both WIP 7 and Rhino 6 suffer from the same affliction.
If you run; “Arc; start, end, direction at start” and both ends are above C plane, is impossible, except for 90* angle, to create parallel to construction plane arc even while working in the top viewport… See attached.
Darius
Arc_Glitch.3dm (20.5 KB)
