Hello, i attachad an image in wich i draw an arc with the directio of a frame but it is taking the direction of the z axix, is it possible to tell it to take the Y direction? Thanks a lot
What you’re doing now is auto-convert the plane into a vector, which just gives you the Z direction by default. If you wish to use the Y (or X) direction instead, you must deconstruct the plane yourself and pick the vector you want.
thanks, i am going to try!!!
it works!!! thanks a lot
