Hi. I returned to an old project I had been working on long ago.
I am preparing the file for CNC, and I would like to tweak the design to make the CNC milling more efficient and less costly.
As you can see in the image below, the profile curves are different on different parts of the groove.
I think using a spherical milling tooltip along the groove will be more efficient. Of course, the design will not be the same, but I am willing to tweak it anyways.
Do you think there is a way to create arcs corresponding to one radius value where the highlighted profile curves are at the moment? I thought I could also try to make an in-between rial between the existing rials and use the pipe tool. But I wonder if I could use the existing rials and always use one circle radius value that adapts to my rials and then split it.
Thank you
