Applying post effects to renderings raytraced in a detail window
Can it be done? Looking around for a setting but can’t find it. Rhino 7
I see that the post effects window shows up in Properties with a Raytraced detail window active, but clicking the + button in the Post Effects panel or the Final Pass panel has no effect, even with Enable Post Effects checked, whether raytracing is either completed or underway. Also the Post Effects toggle icon on the Raytraced Display Mode HUD usually doesn’t change between a star and a star with a strike through it whether Enable Post Effects is checked or unchecked.
It’s turning out that I can’t Raytrace Render from a Viewport unless I have no Details in a layout set to Raytraced View Mode.
I don’t think details supports raytraced windows, I think you have to render to an image and then add that to your layout. I don’t recall it working for me.
RM
Raytraced does not work in details, no.
