Hey guys,
Curves modified with _ApplyCurvePiping inside blocks won’t render in vRay 3.6 in R5. Is there any other solution than exploding the block or using _Pipe?
Cheers
Jonas
Hey guys,
Cheers
Jonas
Hi Jonas - try ExtractPipedCurve
to get the mesh itself into the block.
Thank you guys, I will try tomorrow.
Btw can these Render Tools modifiers be removed from the object?
I exploded the block with piped geometry and re-blocked it again and now the piping only shows up in viewport when the block is open. Otherwise it’s just lines - so I’ve wanted to recreate the piping modifier.
Cheers
Jonas
Thank you, Pascal.
It works, so I guess I can either explode blocks or extract the mesh.
I will start my R6 trial and check if this bug persists.
J.
