Is there an equivalent method of ApplyCrv
in RhinoCommon? I cannot find similar names. Is it a combination of Surface.Pullback
& Surface.PushUp
M. Dale Fugier said ApplyCrv
is actually a transform which I don’t quite understand.
& Surface.PushUp
Hi @gankeyu,
No, there is no such method. I’ve make an issue so we can provide one in the future.
https://mcneel.myjetbrains.com/youtrack/issue/RH-60244
– Dale
Is it available in the C++ SDK?
No, sorry. The smart behind the command are coded in the command.
– Dale
Found a bug.
var curve3d = surface.Pushup(curve, tol);
should be
var curve3d = surface.Pushup(curve2d, tol);
