Apply Weight with FallOff & display values
possible to apply weights across selection of points with FallOff ?
(user entry for range: 1 - 50 for eg)
(in stead of manually setting weight value to each point)
possible to display the weight values for a selection of points ?
weight
Hello - currently, no, not in plain Rhino. It would be possible in a script. I do have something that statically displays point weights, in case that helps for now-
MarkCVWeights.py (1.4 KB)
To use the Python script use RunPythonScript or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
that definitely helps ! thnx again @pascal
