Apply tree structure to a flattened list?
Hi guys,
I have two group of points, one list is flattened and the other one has a specific tree structure. I need to apply this tree structure to the flattened list, so that the points on this list get ordered according to the order of the second list.
I thought this was a task for Member Index but it does not seems to be working. Maybe it is a tolerance issue, but I played with the values a little bit and no luck. I also checked that the points are identified as identical by using cull duplicates with “cull all” option.
PointOrder.gh (15.8 KB)
Any help much appreciated,
Shynn.
If it’s a tolerance issue, you can comapare two point sets with rounding by any means.
PointOrder_re.gh (21.3 KB)
So it was a tolerance issue. Thanks Kim! This will come in handy for further cases.
