Is there a script available for something like this? is it possible?
‘Layer State 01’ Applied to all Detail Views with the Rhino Name ‘Detail 01’ for example.
Thanks in advance.
Thanks in advance.
Is it correct that you want named layerstates to be applied to Details
So if a layer is on or off in the Layerstate, They should be on or off in the Detail?
-Willem
Correct.
The detail would have a specific rhino name.
This file is in R5, but R6 works as well. The project i’m currently working on is in 5.
Example file. Layer States aren’t currently applied to dLayerState to Named Details.3dm (46.6 KB)
etails.
Typically dealing with output of sheets in the hundreds this would be a great time saver.
