Apply emap in rhino 7 doesn't work
I copied the example to apply a texture to an object in c#. It works if I apply a bitmap or a trasparency but not a Emap
the code
        const ObjectType filter = Rhino.DocObjects.ObjectType.Surface |
                             Rhino.DocObjects.ObjectType.PolysrfFilter |
                             Rhino.DocObjects.ObjectType.Mesh;
        Rhino.DocObjects.ObjRef objref;
        Rhino.Commands.Result rc = Rhino.Input.RhinoGet.GetOneObject("Select object to add texture", false, filter, out objref);
        if (rc != Rhino.Commands.Result.Success)
            return rc;
        Rhino.DocObjects.RhinoObject rhino_object = objref.Object();
        if (rhino_object == null)
            return Rhino.Commands.Result.Failure;
        // Select texture
        Rhino.UI.OpenFileDialog fd = new Rhino.UI.OpenFileDialog();
        fd.Filter = "Image Files (*.bmp;*.png;*.jpg)|*.bmp;*.png;*.jpg";
        if (!fd.ShowOpenDialog())
            return Rhino.Commands.Result.Cancel;
        // Verify texture
        string bitmap_filename = fd.FileName;
        if (string.IsNullOrEmpty(bitmap_filename) || !System.IO.File.Exists(bitmap_filename))
            return Rhino.Commands.Result.Nothing;
        // Make sure the object has it's material source set to "material_from_object"
        rhino_object.Attributes.MaterialSource = Rhino.DocObjects.ObjectMaterialSource.MaterialFromObject;
        // Make sure the object has a material assigned
        int material_index = rhino_object.Attributes.MaterialIndex;
        if (material_index < 0)
            // Create a new material based on Rhino's default material
            material_index = doc.Materials.Add();
            // Assign the new material (index) to the object.
            rhino_object.Attributes.MaterialIndex = material_index;
        if (material_index >= 0)
            Texture texture = new Texture();
            texture.FileName = bitmap_filename;
            texture.Enabled = true;
            Rhino.DocObjects.Material mat = doc.Materials[material_index];
            mat.SetTexture(texture, TextureType.Emap);
            mat.CommitChanges();
            //Don't forget to update the object, if necessary
            rhino_object.CommitChanges();
            doc.Views.Redraw();
            return Rhino.Commands.Result.Success;
Thanks
Andrea
@nathanletwory - is this something you can help with?
A post was split to a new topic: EMAP in RH 7 doesn´t work
