AppBuilderSDK Typescript & React incompatible
I pulled the appbuilderSDK from github. While trying to install the dependencies using NPM i in visual studio, I keep running into the issue that:
react-scripts@5.0.1 is only compatible with typescript < 5
@mantine/core is only compatible with typescript > 5
So no matter which typescript version I install, there are compatibility issues.
What is the advised approach?
Kind regards,
Elias
In the current package.json the typescript dependency shows a version >= 5. Please see here.
We switched to pnpm a while ago, but forgot to update the README accordingly. Will do that now. Please use pnpm instead of npm. https://pnpm.io/
This solved the problem, thanks!
