Appbuilder Parameter question
I have a few questions that seem a bit unclear to me about a few of the app builder components.
My question is how I might implement my GH scripts parameters into the appbuilder components, specifically with value lists.
From the example script, it seems to require you to write the name of the parameter in a note box and connect it to the param widget component. Is this how it works? And if so, how would I implement a dropdown value list into the param widget component?
I’ve attached a screenshot of my current parameters and from my understanding, the required components for it to be implemented into the app builder.
You can right-click on your value lists and give them a name. Then you can use this name in a text panel to connect them to a text widget.
