Apparent intersections where is command?
The script runs fine in V6 or later.
In V8, right click in any toolbar and chose “new button”
Choose “Empty button” from the wizard, then hit Next, and Finish.
Shift+right click on the button and you will see the usual two boxes, etc.
Paste in the correct full path to where the script is.
Add tooltips, etc. Add an image if you like.
This one should run in V5, have a go with it.
PointsAtAppIntersectionsV5.py (3.1 KB)
would be awesome to implement a native Rhino command (without using grasshopper) to generate Point in Modelspace at apparent intersections (by End point extension) of two coplanar curves…
just one step faster than using connect, or smarttrackor guides
• for now, do you have a python script by any chance?
I was trying to get the bisector quickly:
