What’s the api to set render model?
What exactly are you trying to achieve? Do you want to start a render?
I want to set a mode that i need not a default mode on the perspective view after open the rhino.
Hi -
You could set the custom display mode in a custom template file that you load at start-up.
Alternatively, you can use the SetDisplayMode
command.
Ok,thanks!
But this still need a person to input ,is there a solution to set it in the program.
Hi -
You can run Rhino commands from within your program.
Ok,I know.Just now I didn’t set a parameter.
