This might actually be a meta question, but what is the difference, generally speaking AND within the Rhino world? I’ve noticed that on the developer docs this menu point says API:
Good catch; there should be a nitpicky badge in discourse we could award you😀 In all of the above cases, I would think API would be the appropriate term to use. SDK is commonly used to mean the same thing, but it is really supposed to refered to the actual download of tools that you would use to interact with an API.
Old discussion, but I still haven’t found the answer…
Additionally, there are some problem: SDK documentation for the Rhino.Display.Text3d Class doesn’t have the VerticalAlignment and HorizontalAligment included in the API, and they don´t seem to work the same way.
For exemple, setting the Rhino.Display.Text3d.VerticalAligment = 3 (mid, in the API documentation) returns an error… but setting the Rhino.Display.Text3d.Italic = True works (SDK documentation)
