Aperture Shadow — net-added shadow studies
Hi all,
I’m a computational designer in Toronto and long time forum reader but first time poster. For the past several months I’ve been building Aperture Shadow, a Rhino plugin for producing sun/shadow studies; specifically the annotated drawing sets that planning submissions require. v2.2 just released and I’d like feedback from this crowd in particular.
What it does
Given a proposed massing and its context, it computes shadows across a series of dates and times and produces the drawing set: each diagram framed and scaled, with date/time tags, a colour legend, scale bar, and north arrow.
It isolates the net-added shadow, the shadow the proposal adds beyond what the existing context already casts. That is what submissions usually ask for, either as colour coded drawing set alone as in Toronto, but often as a measured area as well, and it’s the part that’s most time consuming to produce by hand.
Study setup runs off jurisdiction presets: choose the city, and the dates, times, colour conventions and DST handling are applied automatically. Two Toronto presets are available today, plus an editor for building your own and sharing them across a team.
How it works
It uses two engines in parallel. All the shadow visualization including final drawing export is handled by the lightweight engine that samples every pixel against a mesh constructed from the scene geometry, projecting back along the sun direction to determine shadow attribution. This process is view dependent, and thus gets GPU acceleration and down-sampling in order to run live in the viewport even during pan, orbit and zoom.
The second engine is slower but not view dependent and is opt-in per layer as it is only needed when numeric net-added shadow areas must be calculated. It projects sun-space silhouette curves from the casting geometry onto the receiving mesh, splits the receiving faces along those boundaries, and attributes shadow in the 2D projection. The result is exact shadow boundaries rather than a rasterized approximation.
Requirements and install
Pricing
CAD$79/month individual, CAD$249/month floating (one concurrent user), with a 7-day free trial. Priced for firms doing large-scale development submissions, where producing these by hand runs into days of work each time. If you’re doing something adjacent and that shape doesn’t fit, I’d like to hear what you’re using it for.
Two things I’d like to ask
1. What you did last time. I’ve read a lot of threads here going back to 2015 asking for shadow outlines, hatches and meshes you can work with. So, for anyone who’s needed net-added or coloured shadow diagrams, what did you end up doing last time? Did you build something, and is it still in use?
I’m asking because it decides what I build next. What comes out of Aperture Shadow right now is the finished drawing set, not editable geometry. The engine computes those shadow boundaries internally, so exposing them is on the table, but only if that’s what people actually needed rather than what was available to ask for.
2. Jurisdictions. The preset format is extensible and I want it covering more than Toronto. If your municipality has a shadow study standard, I’d like to hear what it specifies: dates, times, colour conventions. I aim to support most of the conventions out there eventually but will be rolling out presets based on local demand.
Happy to answer anything about the method.
— Alex
