Anyway to export each polysurface as a different dwg file....?
Trying to make my listing process easier.
Brian
This is quite possible with a script - I don’t have one to do exactly this at the moment and no time to write it now unfortunately, maybe tomorrow or someone else can pick up the ball…
What to you want to have as a naming convention for the exported files?
–Mitch
Attached is a rough draft for you to see if it works like you want, it’s easy to modify.
–Mitch
ExportObjsToDWG.rvb(884 Bytes)
WOW…That was quick.
Thank you very much…I’ll try it out and see how it works.
It does exactly what I asked for…Now I got to work on the acad end to see what I can do to make this work.
Brian
