For what it’s worth, I am often unable to select objects even with no clipping planes.
The only way to address this is to get a repeatable sample saved in the state where you see this issue.
The file I attached here still exhibits the behavior I described when I open it. When the red object is selected, other clicks are missed. Clicking the red object again or another object de-selects everything as though I clicked the background, and using shift-select while only the red object is selected doesn’t select additional objects when clicking their faces (clicking edges still works).
Updated SystemInfo:
Rhino 8 SR16 2025-2-3 (Rhino 8, 8.16.25034.21001, Git hash:master @ a6639268785e5c4c20c84d286308a16a30826f3c)
License type: Commercial, build 2025-02-03
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX 2000 Ada Generation (NVidia) Memory: 16GB, Driver date: 9-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.39
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-10-2024
Driver Version: 32.0.15.5639
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp "Rhino Bonus Tools"
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.16.25034.21001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
Hi Measure -
I’m afraid that still isn’t reproducible here.
From that SystemInfo, it looks like you have two monitors. What happens when you run with only one monitor?
Still have the problem with only one monitor.
Thanks.
What are the Windows display settings set to? Are you running at something other than the recommended scaling?
Can we get the display resolution of the monitor with the issue and the monitor that does not have the problem?
Typically making the monitors similar in resolution can resolve some strange and unexplainable issues.
Thanks for your help.
Sorry for the confusion. The issue occurs with both monitors in dual configuration as well as with each one individually.
I managed to reproduce that too and just sent @Gijs an example file!
RH-85940 is fixed in Rhino 8 Service Release 17
