Anyone know of c# source sample for something like the TweenCurve component?
I am very familiar with .net but just getting started with grasshopper … and looking to do a component that is somewhat like tween
wow … pufferfish sure has a ton of stuff ! anychance that is open source? not finding anything on github or searching … so doubtful
Rhinocommon doc is online or in chm version there is also tween curve example
If so create a robust check for the directions (not that easy), open/close mismatch and some visual stuff for the control/greville points and the likes.
BTW: If your goal is to “interpolate” contour curves for terrains … well … that’s way more challenging and is NOT solvable via the tween Method.
Say … something like this:
Screen Shot 027
Crv_interpolation_B34e.pdf (984.8 KB)
Preservingcartographic.pdf (434.1 KB)
Thanks for the info … the topo-line scenario does look hairy.
I am trying to get a tween that
  • acts like a normal tween (2 curves + a factor + a resample option)
  • adds the ability to offset the new tween curve off (normal to) the lofted surface of the original 2 curves
  • added bonus for the offset distance being controlled by a graph input (so variable offset)
In the pic below, the tween is offset by a scale-nu … and then curve-1/tween+offset/curve-2 are lofted into a surface. I am wanting that offset to be 1) normal to the curve1/2 surface and 2) variable offset (so bow can have less).
There is probably an existing component way to do this, but was also thinking a custom component would be nice.
So you are after planing hulls strail (spray) rail, chines and lifting strakes. BTW: What about hull steps (and air induction notches) ? (a must these days).
Post some case (is rather easy to do a C# dealing with all these).
Other than that the near the bow sections are not OK at all … and the transom is flat (i.e. deadrise ~= 0).
Given the opportunity have some fun with the attached (my personal toy designed and build long time ago by yours truly) . Read this (3D PDF) via a standalone Reader app.
171_hull-hull-011.pdf (4.6 MB)
Use Cross Sections AND Model Tree as well
Sorry the code is not on github and it is actually quite a complex component (lots of condition checking). There is some tween methods in rhinocommon but they are by count not by factor.
Very very nice model, even has interior ! also I had no idea you could embed a 3d model in a PDF.
Did you model the engines/drives as well, or are they somehow available from the manuf?
I am actually trying to make a grasshopper script that will help me play around with hull shapes similar to this boat. The earlier screenshot did not have the “bulge slider” for the chine/keel tween set very high so it looks way more V that I am shooting for. (actually just noticed I posted an image with a totally whacked bulge in the front sections … basically why I am trying to get a variable scale/offset of the tween). The real boat has a softish chine in the mid-sections … then also that flat no deadrise aft swim step.
I am thinking that with 3 curves (sheer/chine/keel) and 2 controllable tweens … I could have a neat model to play around with.
Here is the original boat …
more pics here
Here is my model (for the hull the sheer/chine/keel are the only input) … also I am playing around with a plumb bow here as I got tired are playing around with tweening !
Well … back then using Mercury engines was out of question (arhaic stupid tractor engines that supposedly could serve in a fast powerboat - but since that historic Audi deal … well … Mercury Racing is a proper marine I/O engines brand by now). Enter MTU (I had a V16 Model and so I modelled the V8’s). Drives are modelled in house as well (Catia + Siemens NX + Microstation [tests for Bentley Systems and export to 3D PDF as posted]).
Obviously doing stuff like this in Rhino is 1000% out of question.
I don’t have a GH C# that does powerboats since I work in 99% of cases with Generative Components. But I did some time ago an entry level/primitive race sailboat hull layout (Wally type of stuff and the likes) C# in GH just for fun.
Based on that I guess that the powerboat equivalent could require “about” a week of work (~ 60 to 120 hours) and a certain C# experience. If you are novice in C# avoid at any cost.
hmmm … you up for sharing your source? I am a “backend” .net guy, so all servers/databases/services/business-logic stuff … not a lot of nurbs in your average digital banking solution
There’s no source (the likes of GitHub etc). All these are tailor made C#'s for usage within the practice that I own (using Methods from a rather big repository done over the years). Meaning that in 99.99% of cases are strictly internal - but if you are willing to try I could help: so attempt to set-up a C# (see R SDK first for what is exposed) that does something similar and if things become tough, post here the portion of the code/Method that has issues.
Ahh … does not sound like self contained snippets.
So far the tweening C# source examples I have found … just call the tween method in the rhino libs … which is not that useful if you are trying to do a custom tween. It’s like how to you build a car? just call the BuildCar method !
Anyhoo, I found some other hacky ways to get closer to what I am looking for … so will move on for now. Don’t need to bike-shed this and get stuck.
Have in mind that lifting strakes ARE NOT “based” (so to speak) on tween curves anymore. See recent Cigarette Racing/MTI/Outerlimits/etc mono/cat designs: the advance of FD and // computing allows the exploitation of any imaginable solution in no time (if you are Cigarette - or AMG - and have zillions to spend, that is).
