I see that objects will be displayed in the layer color, but I’d like to be able to see the objects in their own base colors if possible…
Thanks!
Thanks!
Hi -
I’m not sure what you mean by “base colors”. Does the Rendered
display mode help?
Hi wim-
Rendered doesn’t help as it isn’t the same type of detail (or speed).
By “base color” I mean something similar to some other systems that show object colors that are based on the colors that the user has applied. If it’s a texture, if not showing the actual texture, this is often done as an “average” of the object color or as a shade of the most prominent color in the texture. If it’s something transparent, it’s usually a shade of the color or texture.
Basically, something like SketchUp shows.
