I have a dark theme build from changing values in the Advanced settings. (Based on info from (IVELIN PEYCHEV) However, importing into Ver 7, it does not work/display as well as in Ver 6. I’d like to make the changes one by one in RH7 and see how it goes. Is there any way to print/export these?
A lot of things changed in that area from V6, so I don’t think importing those settings will be a good idea. You will need to experiment.
These are the basic ones:
Here are the advanced settings.
‘NormalStart’ corresponds to Window color 1 above
‘NormalEnd’ corresponds to Window color 2 above
‘HotStart’ corresponds to Window color 3 above
Edit box colors are controlled by ‘EditBoxBackground’.
