Any vsr like / alias tools making it to rhino 6?
A better example:
Even though the surface in this example hasn’t got a good controlpoint layout, I was still able to match G1 with 8x5 controlpoints. Because of the size, G2 would not made sense anyway (<1mm). It is more important to reduce cp count in order to get a smooth shape, so that the eye doesn’t see a sudden change in curvature within the surface, because G2 can also unsmooth a surface. It also possible to match G2 but loosing G1, This is when curvature is equal but tangency align fails. Anyway an algorithmic matching produced a much worse result, and in Rhino the cpcount would have exploded here. But because of having a deviation analysis, I was able to match it manually ways better…
