Any tips to making icons for the dark mode in the WIP?
I’ve created my toolbars and icons for light mode, and want to now tackle the dark mode. Is there a way to change black in the icons to something lighter without having to remake the svg images? I notice it’s not possible to pick any objects with the hopes of changing the colour within the editor (which would probably be a pretty easy solution for the user).
Thanks,
Dan
I expect this means that the White/Black switch in Rhino’s toolbar system does not witch enough?
When dark mode is active it lightens the fill/stroke colors based on luminance, so near-black line work gets pushed toward white automatically. It’s the same logic exposed in the SDK as Rhino.UI.DrawingUtilities.BitmapFromSvg(..., adjustForDarkMode)
So, substituting a new icon into dark mode it the other way. What SVG editor do you normally use?
Hi Scott,
I’m trying to keep it all within Rhino so I’ve made all of my icons in Rhino and I’m attempting to use the icon editor provided in the beta.
Thanks,
Dan
I have found a free app “Inkscape” to be helpful in making new icons for rhino. Also Ai can help make icons. You could also save some of the native rhino icons and just edit them.
I’ve made a complete set of icons in Rhino. They look great in the light mode, which is my preference. But when I switch to dark mode in the beta the icons don’t look good. Some do, but most don’t. Unless Inkscape has some “trick” to make light mode icons look good in dark mode I don’t see why you can’t just use Rhino. I wish the icon editor in the beta was more capable. Maybe it will be more useful before Rhino 9 is released.
Thanks,
Dan
