Any Tips for SubD Meshing
I keep seeing things like this in SubD Meshing, shown here under surface analysis, but normal mesh shows the same kind of thing.
The Adoptive SubD meshing level is maxed out, too.
The issues are the major mesh um… intersections need an averaging/smoothing pass.
As you can see here, the mesh is pretty fine.
Another interesting area.
note that that is for rendering only. For the analysis mesh to increase you need to use the dialog in the curvature graph analysis tool.
I did. Thank you. No matter where I set it, that shows up.
“…but normal mesh shows the same kind of thing…”
The meshes should have another pass, whereas the joining edge points are matched, averaged, normalized…
Please fix this.
